v7.5.7 -
I filtered only one item, and when I check the bar gauge the width fills all the window.
Can I fix the max size of bar gauge?
I want to keep Min Docc Count 1 since there are so many 0 value items.
The visuality is not that good if the bar width gets so big.
So, I want to fix the max width of the bar.
