Proportions in Bar Gauges
How do we display bar gauges proportionally?
I have tried using it for some metrics and the proportions are not there.
Please refer to the Memory and Operation bar gauges on the left.
Problem solved by setting the values for both Min (0) and Max (1023288) in the Field tab. Thanks, Jtommi, for highlighting this in this thread: [Solved] Bar gauge : Apply threshold color to entire bar - #5 by jtommi
Great.
In the other thread you mentioned that you did set min and max.
Maybe you could point out what you did wrong for other people that did the same mistake
Need to set both Min and Max in the Field tab.
Do not set:
  1. only Max, or
  2. neither Max nor Min
How the dashboard looks like now:
