Good morning.
I am using a bar gauge with some of my data but the all the bars “exceed” the right hand edge of the screen unless I manually set a Max value in the Field section.
How do I make this gauge display the highest value of the data set as the maximum please? Setting them manually won’t work as the values change depending on the time frame.
(I’m sure it’s simple - I’m new to Grafana)
Cheers,
Greg
