Bar Gauge Max Value dos not work
i startet with grafana and needs a bar gauge.
The max value does not work. so the bar is on the left side.
Maby the “auto” max looks at the real max value? I have set the bar to delta.
Hi @bsahrdt,
Welcome to the :grafana: community support forums !!
We are excited that you joined our OSS community. Please read about some of the FAQs in the community :slight_smile:
Try to view some more visualisation by clicking the “suggestions” as also attached in the image as it will suggest some pre-configured panels including bar-gauge with some additional settings for visuals.
I hope this helps.
OK, Thanks. I Can found it.
