I’m on Grafana v8.1.3
From an ELS database I try to do a “Bar gauge”, and … that works, but the automatic Scale fail:
Like you see, the 34, 56 and 97 are on the same level.
Of course, If I add the “max” at 100, it’s ok.
But tomorow I will have 150 or maybe 1000 on value … So I cant use manual scale
So do you think it’s possible to fix that ?
Thank you.
Hi @arethusa
Have you tried the new transformation, Config from Query results? That should be able to set min and max dynamically from the values returned by a query:
Hello @anon70503803
Thank you for your time. I read the documentation, however, I don’t understand what I have to do.
In this configuration, the “Standard options” “Max” is “Auto” so I have the problem previously explain.
I have to find an other option ?
Thank you.
I found options Transform^^
I try to do some test, but nothing works.
I will try to find an other solution.
Thank you.
I would also check out these related issues in the repo:
