Hello
Bar Gauge show strange - should the Temperature not be on the top?
and there is no max or min fixed in the config.
have a nice day
vinc
I think that is behaving correctly, as the temperature scale will change dynamically according to the values
but if you really want to see 28.8C as a ‘high’ temperature,
override Temperatur and put standard unit - max: 30 or 50 Celcius for example
