v10.0.3 (eb8dd72637) -
The following Bar Gauge but without the value displayed as a number at the top.
some of the options depends on the type of graph. I took a screenshot on a column panel instead it was not gauge (my bad), but the options should be similar enough also I had Grafana 9.4.
anyway, I believe it’s kind of intuitive once you start poking around, you will find an option for pretty much everything.
fercasjr,
Thanks. I don’t disagree that it is largely intuitive. I think I am just often missing a few base concepts (seems each app has its own way of doing things) and until I crack the code on what I am missing, I find myself “poking around” for days without getting where I need to go.
That is partly how we all get to some level of expertise along with reading the documentation. And there is no shame asking here if you hit a wall
