10.0.1 -
I am using the Gauge visual and I sometimes have many blank gauges, where their value is Null. -
I have tried using an override:
What happened?
Nothing -
I was hoping the null value gauges would disappear:
No errors -
Closest I could find is this:
But they actually wanted to achieve the opposite of what I want.
Our data source is an sql query. I’m pretty sure there used to be an option to hide null values in previous grafana versions (I can’t remember this being an issue until recent upgrades) I may be wrong though! Any help offered will be gratefully received.
Dan
