Can I hide gauge panels that have zero value
Can I hide gauge panels that have zero value?
Example below has 2 gauge/panels but can I hide one or X if they have zero value?
    7.5.7
    as above
    as above
  • What happened?
    as above
    as above
    n/a
    n/a
    n/a
What is your data source? as the answer may well depend on what data source you are using.
datasource is elastic search. can it be done with that? tks
I am not aware of any Grafana option that allows the entire Gauge panel to disappear when there is no data.
