How to keep all bar gauge queries visible in one panel even if one of them has no data from datasource
Good day to Grafana’s community!
I am trying to make all bar gauge queries visible in case when one or more of them has no data from datasource in one panel. Right now it depends on data existence inside each query. Unfortunately neither “no value” nor “value mappings” settings help me. Could you please tell me if that possible at all and how can I do that?
    v10.2.1
    I want to keep all bar gauge queries visible even if one of them has no data from datasource
    I tried to configure value mappings, no value field
  • What happened?
    It transform data only for whole panel, not for each query
    I hoped that each query will be visible if there is no data in one or more
    no
    no
    dont understand what is online instructions
Use overrides for particular fields so as to configure every gauge independently
I think the best way would be to configure that on datasource side. I.e. return dummy data if there is no real.
what is your datasource and how many queries do you have?
thank you :slight_smile:
