What Grafana version and what operating system are you using? 8.0.4 (81fef5b4b4)
What are you trying to achieve? Define Field Types (Time and Number) for CSV Datasource for a Bar Gauge Panel
How are you trying to achieve it? List the specific fields within the Query definition and then set Value options/Fields equal to All Fields
What happened? The Bar Gauge Panel displays all Fields, rather than just the 2 Columns to Include
What did you expect to happen? The Query filter would be applied/maintained before applying Value options
Can you copy/paste the configuration(s) that you are having problems with? I can only post partial data here from the Query Inspector. But the Schema does not match the response Fields)
“request”: {
“url”: “api/ds/query”,
“method”: “POST”,
“data”: {
“queries”: [
“decimalSeparator”: “.”,
“delimiter”: “,”,
“header”: true,
“ignoreUnknown”: false,
“refId”: “A”,
“schema”: [
“name”: “LastUpdate”,
“type”: “time”
“name”: “Results”,
“type”: “number”
“skipRows”: 0,
“datasource”: “GetAllProjectsData - CSV”,
“path”: “”,
“queryParams”: “”,
“body”: “”,
“datasourceId”: 1,
“intervalMs”: 20000,
“maxDataPoints”: 1102
“range”: {
“from”: “2021-07-06T10:37:42.213Z”,
“to”: “2021-07-06T16:37:42.214Z”,
“raw”: {
“from”: “now-6h”,
“to”: “now”
“from”: “1625567862213”,
“to”: “1625589462214”
“hideFromInspector”: false
“response”: {
“results”: {
“A”: {
“frames”: [
“schema”: {
“name”: “GetAllProjectsDataCsv”,
“refId”: “A”,
“fields”: [
“name”: “Product”,
“type”: “string”,
“typeInfo”: {
“frame”: “string”,
“nullable”: true
“name”: " Status",
“type”: “string”,
“typeInfo”: {
“frame”: “string”,
“nullable”: true
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. No Errors that I’m aware of
To be fair I’m not sure if there is a better way to attempt to do this than including Fields within the Query definition (and then selection the Value option ‘All Fields’. As far as I can tell the CSV datasource defines all Fields as Datatype String
