Version 7.5.15 and Windows. -
Bar Gauge width should update when variable is changed and all values are 0. -
I have used query to fetch data for different duration and using Bar gauge visualization to display it. -
What happened?
Visualization when default variable is selected :
Visualization when variable is updated/changed and all updated values are 0:
Visualization should have changed to the following image when variable was changed.
N/A -
N/A
You can consider this approach to solve your problem; it may prove helpful for you.
Step : 1 Force Panel Refresh
Click on the panel title → select Refresh.
Or change the time range (top-right corner) slightly, e.g. from “Last 7 days” to “Last 8 days”.
See if bar widths reset properly when values are zero.
If it works, then it’s a rendering refresh issue.
Step 2: Set Fixed Min/Max in Bar Gauge
Bar Gauge auto-calculates min/max based on data. When values are all 0, it can’t calculate width correctly.
Bar Gauge panel>Panel settings >Field >Standard options.
Scroll to Min and Max
Set Min = 0
Set Max = fixed value (e.g. 10 or whatever your typical max range is).
This forces the bars to scale consistently, even if all values are 0.
Step 3: Add Transparent Threshold or Placeholder
If you want the bars to still show (even if value is 0), use a threshold color or add a small placeholder value like 0.001:
In Thresholds, add a color range for 0–1 /SQL query, use:
IF(value = 0, 0.001, value) AS adjusted_value
This ensures the bar always renders.
Step 4: Upgrade Grafana if you use older version
Grafana 7.5.15 is very old (released in early 2022). These bugs are fixed in later versions.
Step 5: Debug Panel JSON
panel title → Inspect → Panel JSON
Check if the data source returns correct updated 0 values when the variable changes.
If data is correct, then it’s 100% a visual rendering issue.
final output look like:
Hello @rach1tdani,
Just checking in—did this solution resolve your issue, or are you still experiencing the same problem?
