11.5.2 /InfluxDB v1.11.8 - What are you trying to achieve?
Display the time a metric is collected - How are you trying to achieve it?
Via Grafana Dashboard - What happened?
Time displayed is the current time - What did you expect to happen?
Display time that the metric was collected - Can you copy/paste the configuration(s) that you are having problems with?
Yes - Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
No - Did you follow any online instructions? If so, what is the URL?
*N/A
These are the last 10 entries from Influx
precision rfc3339
select * from ticvalue where MaserName='OoPS’GROUP BY * ORDER BY DESC LIMIT 10
tags: MaserName=OoPS, Server=GPCVWD-PC-01
time tic_value
2025-05-14T16:08:00.000018944Z 50.02031
2025-05-14T16:02:00.016666624Z 50.01723
2025-05-14T15:58:00.00000512Z 50.0171
2025-05-14T15:53:00.000010752Z 50.01563
2025-05-14T15:48:00.000015872Z 50.00941
2025-05-14T15:43:00.000021248Z 50.01324
2025-05-14T15:38:00.00000256Z 50.01585
2025-05-14T15:33:00.000007936Z 50.01966
2025-05-14T15:28:00.000013056Z 50.0142
2025-05-14T15:23:00.000018944Z 50.01826
And these are the last 10 entries shown in the dashboard
Time ticvalue.last
2025-05-14 15:45:00 50.009410 µs
2025-05-14 15:50:00 50.015630 µs
2025-05-14 15:55:00 50.017100 µs
2025-05-14 16:00:00 50.017230 µs
2025-05-14 16:05:00 50.020310 µs
2025-05-14 16:10:00 50.014570 µs
Notice the lines within the double asterisks, the values match but the times do not.
This doesn’t look like “showing local time”:
That looks like a grouping by 5 minutes → why GROUP BY *
Data is written to influxDB every 5 minutes
What are you using to push the data to influxdb? Telegraf or something else
Sorry, I should have said that before, yes telegraf v1.34.2
