Problem with timestamp
I have a problem with dashboard - something is being rendered that is not in the tidal database at all. As far as I can see, the problem will be somewhere in the processing of time stamps.
When I use the query inspector, the time formats do not correspond to me. In the first one I have a unix_timestamp which is correct with a corresponding value.
grafana_problem1
But when I look at the data tab - it shows me wrong. There are also time stamps from the future, and the values are also non-corresponding. And according to these, a graph is drawn for me, which in that case is wrong.
For example:
time: 1680790676000
( GMT: Thursday 6. April 2023 14:17:56)
in data tab is two hours more:
2023-04-06 16:17:56
And then graph not corresponding.
Can you any idea how resolve this?
Thx
Welcome to forum @cesc
In grafana all datetime columns need to be UTC either by design or by the use of a function that converts none utc columns to utc
