I’m using Grafana 8.2.4 and i try to create a link, so a whole Time Series panel gets exported as CSV with only one klick. Its always the same number of curves (4 different curves in one panel) and i would like to use the time range, that is active
I created a link with :
(only an example link, the real link is on my localhost, its not connected to the internet atm).
But this opens a new instance of the graph and then the default time range is set. For example if the initial time range is set to 15min and i change it to 1h, when i use the link, a new instance is opened and the export is 15 min again and not the 1h, i want.
Hope you can understand my problem. Is there a possibility to pass the active time range for csv export ?
