Change of any value in any panel results in Unsaved Changes prompt. : 6.5.0 b1
Don’t want to report this as a bug on GitHub yet, as I’m pretty new to Grafana, and may simply be missing something (or, equally likely, just dumb :slight_smile: ) Looking for ideas/comment here before taking that step.
Not above borrowing the github bug report template though -
What happened:
As soon as any value, in any panel, on any dashboard changes, attempting to navigate away from that dashboard prompts the user to save his/her changes to the dashboard, even though no changes were made.
What you expected to happen:
Not to be prompted to save changes.
How to reproduce it (as minimally and precisely as possible):
Log in as a user with permission to change dashboards. Open any dashboard. Wait for the autorefresh period to expire, and any value in any panel of any type to change. Attempt to navigate away from the dashboard to any other dashboard or menu item.
Anything else we need to know?:
I’ve tested this on dashboards containing graphs, both D3 and default gauges, ImageIt, and single stat panels. All seem to trigger the behaviour. Also seems
Environment:
  • Grafana version: 6.5.0 beta 1
  • Data source type & version: MySQL 8.0.18
  • OS Grafana is installed on: Windows 10 Home
  • User OS & Browser: Windows 10 Home, Chrome 78.0.3904.97
  • Grafana plugins: Default plus D3 Gauge, ImageIt
Any lead on this issue. Is this now raised as a bug or not ?
I have the same annoying issue also. What is going on with this, is it a bug or what??
