Sometimes, when moving from one dashboard to another, after only changing the time range, Grafana will ask if I want to save changes.
Version: 6.3.5
Version: 6.3.5
Yep, it’s still doing it…
…in fact, it’s getting worse now.
It keeps asking to save changes when I am simply changing Dashboards!
Anyone any ideas please?
Probably you have upgraded Grafana and dashboard models are upgraded in the browser. Just save dashboard and you should be fine. You will see what has been updated in dashboard version comparison.
@jangaraj Typical answer from Grafana employee/hard-baked fan…
This is not what @plittlefield experiences… and this happens to me also. Its highly irritating.
I’m so sorry @dev11 that you are irritated, but I can’t help you. Apparently you said “thats enough for me” and you are still here. I’m happy to mark you as ignored user, because you are captious person from my point of view.
I have had long battle in my head wether to write here or not. I know, you will not read it as you have placed me on ignore list, but I strongly feel that writing this is good, because it can warn other potential victims of Grafana and its team.
No, Im not saying people are stupid; just the opposite. Thats because of people wisdom that Grafana has the reputation it has.
Answering me the way you did, you just confirmed what I thought about Grafana team is true. You are all amateurs who (as almost every team of people responsible for project of questionable reputation) are nice as long as there are people complimenting your software. Let people dare to criticise either you and/or your project, than you become agressive, start calling names, add to ignore list, even banning.
All this had happened to me here from teams’ hands. Some time ago, @torkel(project leader) also reacted furiously (incl. calling me a troll (hey, seriously??), even including banning me? For what? I dared to criticise Grafana, and, at the same time, bite his oversized ego !!
Oh yes, you all act in the same, predictable, manner. No criticizing, ladies and gentleman… or risk being publicly ridiculed, called troll (or whatever one will call you), and generally dragged through the mud.
It all comes down to one sentence :: you all are children who need to be taught discipline. And this lesson needs to be rough; like fiasco of Grafana… (oh yes, that’d be the best lesson you could get)
Dont worry, if this is going to happen, this is not going to be because of me (Im not an idiot)/I will stay away from all this.
Hi, going to ignore the rest of the thread and return to the OP.
I’m having the same “issue”, though I don’t know if it is intended or not.
I have a dashboard with links to another dashboard so that users can drill into more details and back again.
e.g.
Dash1 is an overview and has a table with a list of servers
Dash2 is details of that server with a variable for other servers. That means from this dashboard the user can also select another server. This dashboard also has a link back to Dash1, simply called “Back”.
Actions:
It’s that last part that is a bit irritating and breaks the dashboard navigation flow.
Is there a way to disable this?
@xbalayer that’s an interesting case. Maybe try the following in order to try and isolate the conditions for the issues:
Or does it only happen when you follow the specific sequence of steps (Dash1 > Dash2 > link to Dash1) that you described?
Also, I’ve had something like this happen before when using custom panel plugins that were clearly doing something odd. Do you use any custom plugins?
Hi @svetb, thanks for your reply.
Interestingly it only happens in the first scenario. On the second one I can navigate anywhere else and it does not ask to save.
So basically when:
At the moment the only custom panel I have is the World Map plugin Worldmap Panel plugin for Grafana | Grafana Labs
Interesting - the times I’ve experienced the issue are when I’ve used that panel also. I strongly suspect it may be the culprit. It’s probably worth doing a check to see if the issue still occurs if you remove the panel and save. (obviously revert the changes later
If it does still happen in the absence of the panel, it sounds like a bug with Grafana - which should be filed on Github.
If it’s confirmed an issue with the panel then I guess that should be filed too - but that should be much easier to track down.
You are correct, it is that Panel that caused it. I removed it and the problem went away.
Accidentally solved it differently though 1 minute ago
. By setting the dashboard to “Read Only” instead of “Editable” the pop-ups when using the same navigation behaviours. It still allows the user to change the variables from the dropdown and navigate as necessary - but no more pop-up asking to save every time!
I’ll let the World Map Plugin know about this.
Cheers!
Hi everyone, I am experiencing this issue since we upgraded from 6.2.4 to Grafana 8.3.2 recently. We don’t use the World Map Plugin.
Here is what we use with the docker image grafana/grafana:8.3.2
GF_INSTALL_PLUGINS: grafana-piechart-panel,jdbranham-diagram-panel
I’ve noticed that I have this problem only with dashboards that contain Rows. The steps to reproduce is:
Please let me know if you need more details.
Note that saving once does not help. I can save it on each encounter and it keeps happening next time I open the dashboard, which only contains simple Timeseries line charts from Graphite in two rows.
I have the same problem after upgrading to 8.5.0.
In my case, it is enough to use the browser scroll bar.
I did not notice the connection with the types of panels - only the scrollbar.
I’m getting the same issue on 8.5.1 scrolling is all it takes to prompt a save
Did a manual save and then saved upon being prompted to and did a version compare
Compare is full of:
changed pluginVersion 8.3.3 8.5.1
And a bunch of set value to Null
But then it keeps prompted to save and each save after that has zero changes in the version compare only a version number change
I have the same issue lots of added “null values”
EDIT: Solved upgrading Grafana to 9.0.2
Any updates on this issue? I’m running Grafana v9.0.7 (eed942a502) with Geomap 5.0.0. I have narrowed the problem down to the Geomap panel. If I delete the panel, the dashboard works fine. If I include a Geomap, it constantly asks to save changes. If I click “save changes”, it says there are no changes to save.
EDIT: Not a fix, but a workaround is to set the dashboard to “read-only”.
