<these blue bars appeared to my dashboard suddenly and I can’t remove them? Now my dashboard is mega slow!–
GRAFANA FORUM’S 3 BEST PRACTICES:
- Please post inside a subcategory
- For questions and advice, please try to use the template below
- If you post a question and someone solves it, please mark is as SOLVED
~ THANK YOU!! the grafana team
What happened?
