Hi Guyz,
i have recently upgraded Grafana from 7.0 to 8.1.1, noticing annotations are by default enabled on dashboards?
How can i turn annotations off by default, and manually enable on the dashboard on which i need them to setup?
With the default behaviors, both annotations and alerts are showing in same Cyan color and its confusing to differentiate and its difficult task for us to go to each dashboard and set the color scheme to red for alerts and disable annotations.
Thanks in advance.
Regards,
Naveen.
