Grafana 8.4.7 in alpine 3.15 (docker image built from stock Dockerfile). -
Display annotations content in a table. -
Imported dashboard from Grafana 6.6.1 where it works flawlessly. -
What happened?
Annotations are visible on graph(old) panels, but table(old) panel says it has no data to show. -
The same behavior as in Grafana 6.6.1 - annotations are visible on both graphs and, in more precise manner - in table panel to examine annotation text more easily (in fact these annotations are device syslogs). -
Here is panel JSON as it was imported into Grafana 8:
"id": 25,
"gridPos": {
"h": 6,
"w": 24,
"x": 0,
"y": 1
"type": "table-old",
"datasource": {
"uid": "$datasource"
"description": "This panel shows the annotations (syslogs, debug alerts) in a tabular format. If \"No data to show\" message is displayed, either annotation checkboxes were disabled in a top control row, or there were no logs for this period of time.",
"links": [],
"columns": [],
"fontSize": "100%",
"scroll": true,
"showHeader": true,
"sort": {
"col": 0,
"desc": true
"styles": [
"alias": "Time",
"align": "auto",
"dateFormat": "YYYY-MM-DD HH:mm:ss",
"pattern": "Time",
"type": "date",
"$$hashKey": "object:373"
"alias": "",
"align": "auto",
"colors": [
"rgba(245, 54, 54, 0.9)",
"rgba(237, 129, 40, 0.89)",
"rgba(50, 172, 45, 0.97)"
"decimals": 2,
"pattern": "Title",
"thresholds": [],
"type": "hidden",
"unit": "short",
"$$hashKey": "object:374"
"alias": "",
"align": "auto",
"colors": [
"decimals": 2,
"pattern": "Tags",
"thresholds": [],
"type": "hidden",
"unit": "short",
"$$hashKey": "object:375"
"alias": "",
"align": "",
"colors": [
"decimals": 2,
"link": false,
"mappingType": 1,
"pattern": "Text",
"preserveFormat": true,
"rangeMaps": [
"from": "",
"text": "",
"to": ""
"sanitize": true,
"thresholds": [],
"type": "string",
"unit": "short",
"valueMaps": [],
"$$hashKey": "object:376"
"alias": "",
"align": "auto",
"colors": [
"decimals": 2,
"pattern": "/.*/",
"thresholds": [],
"type": "number",
"unit": "short",
"$$hashKey": "object:377"
"targets": [
"refId": "A",
"target": ""
"transform": "annotations",
"pageSize": null
And here is the same JSON from Grafana 6:
"datasource": "$datasource",
"columns": [],
"fontSize": "100%",
"gridPos": {
"h": 6,
"w": 24,
"x": 0,
"y": 1
"id": 25,
"links": [],
"options": {},
"pageSize": null,
"scroll": true,
"showHeader": true,
"sort": {
"col": 0,
"desc": true
"styles": [
"alias": "Time",
"align": "auto",
"pattern": "Time",
"type": "date"
"alias": "",
"align": "auto",
"colorMode": null,
"colors": [
"decimals": 2,
"pattern": "Title",
"thresholds": [],
"type": "hidden",
"unit": "short"
"alias": "",
"align": "auto",
"colorMode": null,
"colors": [
"decimals": 2,
"pattern": "Tags",
"thresholds": [],
"type": "hidden",
"unit": "short"
"alias": "",
"align": "",
"colorMode": null,
"colors": [
"decimals": 2,
"link": false,
"mappingType": 1,
"pattern": "Text",
"rangeMaps": [
"from": "",
"text": "",
"to": ""
"sanitize": true,
"thresholds": [],
"type": "string",
"unit": "short",
"valueMaps": []
"alias": "",
"align": "auto",
"colorMode": null,
"colors": [
"decimals": 2,
"pattern": "/.*/",
"thresholds": [],
"type": "number",
"unit": "short"
"targets": [
"refId": "A",
"target": ""
"title": "",
"type": "table"
No errors. In networking debug page I see that annotations request is successful and that all the graph panels show them as expected => only table panel behaves not as expected. -
No.
Screenshot of Grafana 6.6.1 with expected behavior:
