Grafana 9.0.3 (self-hosted) - Centos 8 Stream -
Displaying annotations queried from a MySQL database in both a Time Series panel and an Annotations panel. -
Dashboard SQL query called “annotations” extracts messages sent by monitoring system in the format needed for query-based annotations supplyingtime_secandtext. -
What happened?
Annotations are displayed correctly in Time Series panel, but not in Annotations panel. Only manually-entered annotations appear in the Annotations panel. -
It seems that all annnotations should appear on the Annotations panel, whether query-based or manually-entered. -
- Dashboard query called “Notifications”:
SELECT
UNIX_TIMESTAMP(start_time) as time_sec,
output as text
FROM icinga_notifications n JOIN icinga_objects o ON n.object_id = o.object_id
WHERE $__timeFilter(start_time)
AND o.name1 = $sel_hostname
AND o.objecttype_id = 1
AND o.is_active = 1
ORDER BY start_time ASC
LIMIT 100
$sel_hostname is a variable allowing the viewer to select a specific host.
No errors. -
- MySQL | Grafana documentation (Annotations section)
