Grafana v10.0.3 (eb8dd72637) on Docker
- What are you trying to achieve?
I am trying to view all my annotations on a dashboard. These annotations have been visible for months and now they are gone. As of today, only annotations made today are showing. I recently upgraded from Grafana v9.x to v10.0.3 but I’m not 100% sure that this issue is related to the upgrade.
- How are you trying to achieve it?
I am using the SQLite database to store annotations. I can see the annotations (in the annotations table) in the database using DB Browser for SQLite. I can also query annotations using the API. For example, here are two entry that is in the database and that is return by the API. The first one shows in the GUI but the second one does not.
Shows in GUI
Annotation Table
| id | org_id | alert_id | user_id | dashboard_id | panel_id | category_id | type | title | text | metric | prev_state | new_state | data | epoch | region_id | tags | created | updated | epoch_end |
| 84909 | 1 | 0 | 4 | 20 | 0 | Start eraserltemp.vbs | {} | 1691596803000 | 0 | [eraserltemp.vbs] | 1691596803677 | 1691596865124 | 1691596865000 |
Annotation Tag Table
| id | annotation_id | tag_id |
| 1092 | 84909 | 10 |
Does NOT Show in GUI
Annotation Table
| 84367 | 1 | 0 | 4 | 20 | 0 | Start eraserltemp.vbs | {} | 1691510404000 | 0 | [eraserltemp.vbs] | 1691510405502 | 1691510476088 | 1691510466000 |
| 1045 | 84367 | 10 |
JSON Query to Annotation API
Query:
http://localhost:3003/api/annotations?tags=eraserltemp.vbs&limit=2
Results:
“id”: 84909,
“alertId”: 0,
“alertName”: “”,
“dashboardId”: 20,
“dashboardUID”: “dPGkzem4k”,
“panelId”: 0,
“userId”: 0,
“newState”: “”,
“prevState”: “”,
“created”: 1691596803677,
“updated”: 1691596865124,
“time”: 1691596803000,
“timeEnd”: 1691596865000,
“text”: “Start eraserltemp.vbs”,
“tags”: [
“eraserltemp.vbs”
“login”: “sa-pause-alerts”,
“email”: “sa-pause-alerts”,
“avatarUrl”: “/avatar/783a6ae320953901d76160ccef2a4639”,
“data”: {}
“id”: 84367,
“alertId”: 0,
“alertName”: “”,
“dashboardId”: 20,
“panelId”: 0,
“userId”: 0,
“newState”: “”,
“prevState”: “”,
“created”: 1691510405502,
“updated”: 1691510476088,
“time”: 1691510404000,
“timeEnd”: 1691510466000,
“tags”: [
“eraserltemp.vbs”
“data”: {}
Screenshot from last 7 days
The visible annotation has time in the json response as:
which translates to GMT : Wednesday, August 9, 2023 4:00:03 PM
The non-visible annotation has time in the json response as :
which translates to GMT : Tuesday, August 8, 2023 4:00:04 PM
JSON Model snippet
I cannot include the entire dashboard because of character limitations in the post but here you see the UID for the dashboard.
“timezone”: “browser”,
“title”: “Windows Host Overview”,
“uid”: “dPGkzem4k”,
“version”: 12,
“weekStart”: “”
- What happened?
I don’t know exactly. Maybe the upgrade?
I expect to see all my annotations. I have a lot of them on this system but I’m not seeing any beside the one from today.
No
- Did you follow any online instructions? If so, what is the URL?
No
