We are creating an HMI control panel in Grafana and are running into trouble adding all the metrics we need due to the 26 queries/panel limit. We may need up to 50 queries. Has anyone found a workaround for circumventing this limit with Grafana panels?
We managed to get our provider to upgrade our version to 10.x. What we see now is that there is a warning that the plugin uses “a deprecated legacy platform based on AngularJS”, and we can now display 29 values instead of 26, but not more than 29. Does anyone know if there is a relationship between this deprecation notice and the limitation, or if there are any other limitations related to flowcharting panels? We are using this plugin: FlowCharting plugin for Grafana | Grafana Labs
So it has probably not been written to take advantage of React instead of Angular… Probably a good idea to reach out to the developer/maintainer for support or find another plugin with similar functionality…
