Grana 9.2.4. Debian Bullseye -
Create a wind chill plot -
See Below - What happened?
It worked - What did you expect to happen?
For it to work - Can you copy/paste the configuration(s) that you are having problems with?
See Below, requesting a peer review to ensure I got the statements correct. - Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
No - Did you follow any online instructions? If so, what is the URL?
Not Applicable
import “math”
//double w = 13.12 + 0.6215t + (0.3965t - 11.37) * Math.pow(v, 0.16)
p = 0.16
ot = from(bucket: “netatmo”)
|> filter(fn: (r) => r[“_measurement”] == “Temperature”)
|> filter(fn: (r) => r[“module”] == “outdoor”)
|> filter(fn: (r) => r[“station”] == “Maison (station)”)
|> truncateTimeColumn(unit: 1m)
|> aggregateWindow(every: v.windowPeriod, fn: mean, createEmpty: false)
|> keep(columns: [“_time”, “_value”])
ws = from(bucket: “netatmo”)
|> filter(fn: (r) => r[“_measurement”] == “WindStrength”)
|> filter(fn: (r) => r[“module”] == “wind”)
wc = join(tables:{ot:ot, ws:ws}, on:[“_time”])
//|> map(fn:(r) => ({ time: r._time, _value: float(v: r._value_ws) * float(v: r._value_ot)}))
|> map(fn:(r) => ({ time: r._time, _value: (13.12 + (0.6215 * float(v: r._value_ot) + ((0.3965 * float(v: r._value_ot) - 11.37) * (math.pow(x: float(v: r._value_ws) , y:p)))))}))
//|> aggregateWindow(every: v.windowPeriod, fn: mean, createEmpty: false)
|> drop(columns: [“_result”])
//|> mean()
|> yield()
