How To configure a plugin?
Hi All,
I am new to grafana and very impressed. Im using grafana 4.6.3 on a raspberry pi 3 with influxdb to visualize wind speed and direction data from a network-connected sensor. I installed a plugin that appears to do exactly what I want. See this link for the plugin in use elsewhere:
https://weather.ksz.ch/grafana/dashboard/db/wind-rose-github?orgId=1&from=now%2Fd&to=now
My site is not available publicly at the moment but I have installed the plugin using a git clone and I have been able to place a new panel of type windrose but I am not having any success in configuring the panel to show the data as I am seeing it displayed on the site linked above.
I know that the data elements exist and are being displayed in a soimple time-series graph, but I would like to see them in this windrose graph. What can I do to troubleshoot here?
TIA
Oh right, interesting. Is the plugin code public available somewhere so that I can try it out?
Marcus
Code is here. (not mine)
Thanks. I would suggest you to create an issue in that repository asking for help of your problem.
Marcus
I was able to configure this plugin with a few code modification explained here
The result is pretty good.
