Grafana 9.2.3 Debian Bullseye -
Getting the WindRose to work with Flux -
from(bucket: “netatmo”)
|> filter(fn: (r) => r[“_measurement”] == “WindAngle” or r[“_measurement”] == “WindStrength”)
|> filter(fn: (r) => r[“module”] == “wind”)
|> filter(fn: (r) => r[“station”] == “Maison (station)”)
|> filter(fn: (r) => r[“_field”] == “value”)
|> aggregateWindow(every: v.windowPeriod, fn: mean, createEmpty: false)
|> yield(name: “mean”) -
What happened?
No data or compass rose lines, but using Inspect I see the data -
Wind Speed and Wind Direction (which worked on the postgres data source) -
see above Flux -
None. -
None Available
fixed it
|> filter(fn: (r) => r[“_measurement”] == “WindStrength” or r[“_measurement”] == “WindAngle”)
|> pivot(rowKey:[“_time”], columnKey: [“_measurement”], valueColumn: “_value”) // put dir and speed values into the same row based on timestamps
|> filter(fn: (r) => exists r[“WindAngle”] and exists r[“WindStrength”]) // drop rows that donot have both values
|> rename(columns: {“WindAngle”: “direction”, “WindStrength”: “speed”})
//|> map(fn: (r) => ({ r with direction: r.directionRad / 3.14 * 180.0 })) // convert to degrees from radians
//|> map(fn: (r) => ({ r with speed: r.speedMps / 0.514 })) // convert to knots from m/s
|> aggregateWindow(every: v.windowPeriod, fn: first, column: “direction”, createEmpty: false) // sample the first row for each window (real aggregation would show fake values in gusty winds)
