How to graph the delta (difference) between indoor and outdoor temperature
    v9.3.6
    To display the delta between indoor and outdoor temperature
    BY filtering on indoor and outdoor temperature and using Transform
  • What happened?
    Don’t know how to do it.
from(bucket: “my_bucket”)
|> filter(fn: (r) => r[“entity_id”] == “outside_temperature” or r[“entity_id”] == “indoor_temperature”)
|> filter(fn: (r) => r[“_field”] == “value”)
|> aggregateWindow(every: v.windowPeriod, fn: last, createEmpty: false)
|> yield(name: “last”)
    No errors
    I was not able to find instructions.
When you send the data to InfluxDB, is the timestamp the same for the indoor temp and outdoor temp?
Yes, the timestamp is the same.
@snowmangh
Maybe something like this?
from(bucket: "my_bucket")
  |> filter(fn: (r) => r["entity_id"] == "outside_temperature" or r["entity_id"] == "indoor_temperature")
  |> filter(fn: (r) => r["_field"] == "value")
  |> pivot(rowKey:["_time"], columnKey: ["entity_id"], valueColumn: "_value")
  |> map(fn: (r) => ({ r with delta: (r.setpoint - r.actual)}))
  |> yield(name: "delta")
I cannot check the above syntax, but it should be close to correct.
Thanks for the suggestion. After a re-verification, the timestamp is not quite the same. My bad.
I ended up using the experimental.fill function to draw the delta. Works great, but experimental.
import "experimental"
  |> filter(fn: (r) => r[“outside_temperature” or r[“entity_id”] == “indoor_temperature”)
  |> experimental.fill (usePrevious:true)
