Why my output on the panel is not tally with other panel?
Pic 1
Pic 2
So here’s are the problem. At first, after 2 weeks of alloy deployment everything seems fine. But after that, whenever I set the range to be the last 7 days, the data is not tally as shown in Pic 2. It should be the same for every panel as in Pic 1. Why did this happened ? Is it because of a bug ? Already tried to restart the grafana service but the output is still the same.
Grafana version: v11.1.3
OS used: Unix environment
Query for each panel are shown below:
Most frequent logon type:
topk(20, sum by (LogonType) (
  count_over_time(
    {channel="Security", computer=~"$computer"} |= "$search" !~ "DWM" !~"UMFD" !~ "ramcosupport" !~ "Ramcoerpusr_app" !~ "dashboard.user"
    | json
    | line_format "{{.event_data}}"
    | event_id=~"4624"
    | regexp "<Data Name='LogonType'>(?P<LogonType>[0-9]+)<"
    | LogonType=~"^(2|7|9|10|11)$"
    [$__range]
    #[7d]
Top account by logon:
topk(20,
  sum by (TargetUserName) (
    count_over_time(
      {channel="Security", computer=~"$computer"} |= "$search" !~ "DWM" !~ "UMFD" !~ "ramcosupport" !~ "Ramcoerpusr_app" !~ "dashboard.user"
      | json
      | regexp "<Data Name='TargetUserName'>(?P<TargetUserName>[^<]+)<"
      | event_id=~"4624"
      #[7d]
      [$__range]
Top source IPs by logon count:
topk(20,
  sum by (IpAddress) (
    count_over_time(
      {channel="Security", computer=~"$computer"} !~ "DWM" !~ "UMFD" !~ "ramcosupport" !~ "Ramcoerpusr_app" !~ "dashboard.user" !~ "ramcoerpusr_app"
      | json
      | event_id="4624"
      | regexp "<Data Name='IpAddress'>\\s*(?P<IpAddress>[^<]+)<"
      | IpAddress!=""
      | IpAddress!="-"
      [$__range]
      #[7d]
Most frequent event ID:
sum by (event_id) (
  count_over_time(
    | json
    | event_id=~"4624|4634"
    [$__range]
Alloy config file:
// Existing component to scrape the active “Security” Windows Event Log channel
loki.source.windowsevent “security” {
eventlog_name = “Security”
use_incoming_timestamp = true
forward_to = [loki.write.endpoint.receiver]
// Writes the processed logs to the Loki server
loki.write “endpoint” {
endpoint {
url = “http://IP/loki/api/v1/push”
// Enables live debugging for troubleshooting
livedebugging {
enabled = true
Loki config file:
auth_enabled: false
server:
  http_listen_port: 3100
  grpc_listen_port: 9096
  http_server_write_timeout: 5m
  http_server_read_timeout: 5m
common:
  instance_addr: 127.0.0.1
  path_prefix: /tmp/loki
  storage:
    filesystem:
      chunks_directory: /tmp/loki/chunks
      rules_directory: /tmp/loki/rules
  replication_factor: 1
  ring:
    kvstore:
      store: inmemory
query_range:
  max_retries: 5
  parallelise_shardable_queries: true
  results_cache:
    cache:
      embedded_cache:
        enabled: true
        max_size_mb: 100
limits_config:
  split_queries_by_interval: 12h
schema_config:
  configs:
      store: tsdb
      object_store: filesystem
      schema: v13
      index:
        prefix: index_
        period: 24h
ruler:
  alertmanager_url: http://localhost:9093
frontend:
  encoding: protobuf
  max_outstanding_per_tenant: 4096
  compress_responses: true
# By default, Loki will send anonymous, but uniquely-identifiable usage and configuration
# analytics to Grafana Labs. These statistics are sent to https://stats.grafana.org/
# Statistics help us better understand how Loki is used, and they show us performance
# levels for most users. This helps us prioritize features and documentation.
# For more information on what's sent, look at
# https://github.com/grafana/loki/blob/main/pkg/analytics/stats.go
# Refer to the buildReport method to see what goes into a report.
# If you would like to disable reporting, uncomment the following lines:
#analytics:
#  reporting_enabled: false
When making a stats panel with one metric only, you’ll want to make sure your query actually return only 1 value. There are two ways to do it, and I’d recommend double checking on this
Solution 1: Make sure your panel is limit to 1 data point, and query option is set to instant query. This will ensure your query only returns 1 data point.
Solution 2: in your stats panel make sure the value presented is sum from all data points.
Also, I’d check your query inspector and see what the queries actually look like.
Hi , thanks for the reply. I’m sorry but actually I did not understand for both solution. Can u elaborate more ? Thank you for your understanding. Below are the query inspector for each panel:
Top accounts by logon:
Top source IP by logon:
Thank you for your assistance and understanding.
Probably focus on one graph at a time. Pick a graph, go to query inspector, then get the query and data returned for both 2-day and 7-day interval, and see what the differences are.
Again, you either want to run a 1-time query with the interval, or you want to make sure you sum the value using the stats graph.
