Okay back for another round of questions.
I have a dashboard that gets application logs with different level (ERROR, INFO, WARN). I have two panels:
- a log panel that is supposed to show all log lines in the dashboard range.
- a piechart panel that counts how many of each levels we got within the range.
The issue is that something is off. Looking at Loki datasource I have 2 lines at 7 hour range and 26 lines at 8 hour range.
The log panel is correct, it shows the correct number of lines for both 7 and 8 hour time. All it does is a line_format operation.
The issue is that the piechart always shows 26, for both 7 and 8 hour time range.
How can this be? It seems to me that the piechart range is getting more than it is specified.
