i am new in grafana and i have some problems.
- linux, Grafana 9.1.8.1, data source Loki
- What are you trying to achieve?
- It is about logs that I want to count
I have several instances that log events every day. An event can occur several times on one instance.
Now I want to build a dashboard:
I want to count the events for the current day, the previous day and the last 7Days.
I want to sort everything by instances. It doesn’t matter how many times the event occurs per instance.
Example:
Instance 1 logs 10x the event
Instance 2 logs 1x the event
Instance 3 logs 7x the event
At the end there should be a 3. This means that the event has occurred on 3 instances.
And I want to display this for: today, yesterday, last 7 days.
My queries:
today
count(sum by (instance) (count_over_time({event=~“.+”}[24h])))
and in the panel option "Qeuery Options
Relative time: now-1d/d+24h
Time shift:
yesterday
Relative time: now-1d/d+0h
Time shift: 1d/1d+0h
last 7 days
Relative time: now-7d
Time shift:
What happened?
The 7 Days query has the same result as the today query. The number should be higher.
And the yesterday panel has the last 2 days, i think… -
I thought that if the relative time settings were different, the queries would produce different results.
What did I do wrong? I’ve been sitting on it forever and can’t figure it out.
