Grafana v8.3.4 @ CentOS 7 -
Trying to interpret a custom variable in 2 ways; it’s key and it’s value. -
I’ve got 2 custom variables on my dashboard.
VAR1 equals group of key-values:QA : group1|group2|group3
VAR2 equals group of key-values:QA2 : group4|group5|group6- So, if I use it on a dashboard as
${VAR1:raw}, it works correctly — I get a group of values passed to a Prometheus datasource. The question is — can I use the same variable, VAR1 or VAR2, in a different way, to get it’s key as a value and pass it to my Elasticsearch datasource? So that query would become something like${VAR1:key}
What happened?
Dasboard doesn’t display any information. -
Dashboard loads properly, custom variable’s key can be used as a value in query. -
Custom variable VAR1:QA : group1|group2|group3
Custom variable VAR2:QA2 : group4|group5|group6 -
No. -
