Variable to group multiple values under one key
Create repeating panels based on “Areas” grouped by energy sensors in a building.
The sensors have unique IDs and names but I am struggling to create groups like:
Mains: 1, 2, 3
Kitchen: 4, 5
Common: 6, 7, 8
Where I and the client can select Mains and/or Common and have that metric panel repeated without creating a separate panel for each area. I am doing this at the minute.
I understand that the values in a custom variable are comma separated so it is reading each one as a new option for the drop down list. I have also tried using variables to pull in the list but can’t get it to work.
The information is stored in a timeseries DB
  • What happened?
Custom Variable Key : value doesn’t seem to be able to store more than one value like a Python dictionary
Store multiple values under one key so it would pull those values into the query and display the results in a panel
Mains : Mains Incoming, Main 1 Hotel Feed, Mains 2,
Kitchen : SDB 6, MCC 6, SDB 55
Only Mains Incoming or SDB 6 metrics show when Mains or Kitchen is selected
    No
    Trying to follow the variable syntax Variable syntax | Grafana documentation
welcome @ronanconnor
use the infinity data source csv. 2 variables, one shown the other hidden
This would be better done in a sql databasse so it can be set to be dynamic and you do not need to come into these variables when you have new rooms and sections etc.
  1. variable name rooms
infinity csv
room
Mains
Kitchen
Common
  1. variable name sections, set to Nothing which hides it
__value,__text
Mains,1
Mains,2
Mains,3
Kitchen,4
Kitchen,5
Common,6
Common, 7
Common, 8
you just created a parent child relationship.
you can then filter this second list based on a where clause for infinity csv and use something like where __value = $rooms
see doc: UQL
Then your repeat can happen on either ${sections:text} or ${secions:value}
Hey @yosiasz
Thanks for the speedy response I will give this a go
Ronan
looks like infinity is not the way to go, there seems to be an issue on the sections variable. best to go with a db route would be my recommendation.
