Custom variable key:value pairs - list keys in csv format
    Linux v8.4.6
I have a table (my_stats) which contains rows like below
ts,src_ip,src_port, dst_ip,dst_port,metric
I also have a table (hostnames) for mapping ip to hostname
ip,hostname
I have a multi-select variable on a dashboard for a user to select the fields they want to aggregate the metric by
In order to provide the hostname for the src_ip and dst_ip I do joins but both columns come back as ā€˜hostname’ which Grafana complains about and would also be confusing to a user.
One approach is to use a custom variable with key:value pairs like this:
src_ip : stats.src_ip,src_hostname : src.hostname AS src_hostname, src_port : stats.src_port, etc…
I can then reference the values in the selected columns and the keys for the group by
Select ${TABLE_FIELDS:raw},sum(metric) AS total_metric
FROM my_stats AS stats
INNER JOIN hostnames AS src ON stats.src_ip = src.ip
INNER JOIN hostnames AS dst ON stats.dst_ip = dst.ip
WHERE
$__timeFilter(ts)
GROUP BY ${TABLE_FIELDS:text}
ORDER BY total_metric DESC
LIMIT 10;
  • What happened?
The keys are listed as src_ip + src_hostname + src_port + dst_ip + dst_hostname + dst_port
The keys to be listed as src_ip,src_hostname,src_port,dst_ip,dst_hostname,dst_port
Is this possible?
What is your data source?
You want them concatenated? What are the + signs for?
Data source is MySQL. The + signs are showing when I use ${TABLE_FIELDS:text}, I don’t want the + sign I want comma separated but I can’t see how to do this when listing the variable keys.
The query ends up like this:
SELECT stats.src_ip,src.hostname AS src_hostname,stats.src_port,stats.dst_ip,dst.hostname AS dst_hostname,stats.dst_port,sum(metric) AS total_metric
WHERE
$__timeFilter(ts)
GROUP BY src_ip + src_hostname + src_port + dst_ip + dst_hostname + dst_port
LIMIT 10;
I want the query to end up like this:
WHERE
$__timeFilter(ts)
GROUP BY src_ip, src_hostname, src_port, dst_ip, dst_hostname, dst_port
LIMIT 10;
So you want to do dynamic query. I would recommend you do all this in mysql for example in a stored procedure.
All I need is to be able to list the keys in csv format instead of with a + sign but there doesn’t seem to be a formatting option to do this as ${variable:text} is the only option I’ve found which lists the keys and unfortunately lists them with a + sign. All other formatting options like ${variable:raw} and ${variable:csv} list the values not the keys.
how about
${servers:csv}
Unfortunately, that prints out the values and not the keys.
My variable is ā€œsrc_ip : stats.src_ip,src_hostname : src.hostname AS src_hostname, src_port : stats.src_portā€ as per this improvement - Variables: Adds support for key/value mapping in Custom variable by sartaj10 Ā· Pull Request #27829 Ā· grafana/grafana Ā· GitHub
The issue is I can format how the values are listed in the query using all the options in that page you linked to, but there is only one option to output the list of keys which is ${variable:text} and that is using a + sign whereas I want to use a comma.
Is there any setting file where I can change the + sign being the default for listing they keys? Or even somewhere in the code I can change it?
Thanks
