Access to the value of a custom variable key:value from another custom variable value
Hi folks,
I have started building an interface using Grafana 10.4.1 and I’m looking everywhere to solve the problem in the topic, but I have not found any solution. I have read many posts about it and they all refer to using chained variables with query variable. I just want to use custom variables.
The result I want to achieve can be of two types:
The first one could be get the value of a custom variable setting the key from another one.
Ex:
$variable1 contains (var1 : 0, var2 : 1)
$variable2 contains (0 : 101, 1 : 200)
Result = $variable2[variable1]:value.
In alternative i can put more than one value inside a custom variable like for example
Ex:
$variable1 contains (var1 : { 0, 101}, var2 : { 1, 200})
and access to this values in some ways.
How can i achieve one of these two solutions ?
This solution does not entirely solve my problem, because I need to keep as a key an explanatory label to be displayed in the menu, while the other pair of data would correspond to an ID and a value to be associated with it.
Am I wrong or this solution show both menus for variable 1 and variable 2?
I need to have something like this, a dropdown menu where i can select the element using the label and then i get the id and the relative value from another variable, but is not possible to associate 2 variables. I mean probably i need to use the chained variable but I could not find any examples using them with custom variables.
Screenshot 2024-03-28 094137
I generally need to use the CARS_PAIRS value and text but i need to select the cars from the CARS variable that rappresents the dropdown menu for the user.
really ugly workaround:
1st variable: list of cars, and “models” in csv ( i used inline, but you can use a url, and get a dynamic list)
2nd variable: json array of “models” and “prices”, then filtering by getting value from the 1st selected variable
result: one drop down showing cars to select, “price” returned from json array
This is not very elegant, and can probably be simplified, but it works, and it took a surprisingly long time to do such a “simple” task…
Hello, is it possible to replace the selected number with a string in the JSON input? Something like this does not work for me:
“016” : [“word”],
“020” : [“sentence”]
Thanks
For some reason only the following example Simple Queries · JSONata allows me to replace the number with a string:
{ “ref”: [ “top”,2 ] },
{ “ref”: [ “middle”,4 ] },
{ “ref”: [ “bottom”,5 ] }
This doesn’t work for Grafana v7.5
