Grafana variables - custom query to inject my dynamic query
    Grafana cloud Pro (Grafana v10.2.0-59542pre)
    Dynamic panel query using custom variable
    using custom query with key values in the context of grafana variables.
  • What happened?
    The value from the key in the custom variables is not placed in the query as expected.
I have a a predefined variable (text box) named traceId.
I created a custom variable name services with the billow key value
key: get-traces
value: /group/find/all/${traceId}/
example record from the logs:
In my logs panel query i was expected to filter all the logs using this query when i type in my predefined variable “YTE27369”
{env=“$env”, app=“$app”, filename=~“$filename”, http_method=“POST”} | json | http_url =~ .*$services
It look like the query not parsing the values /group/find/all/${traceId}/ when i select get-traces from services variables.
    Didn’t find any.
Query inspector
Expr: {env=“dev”, app=“apple”, filename=~“/log/audit.log”, http_method=“POST”} | json | http_url =~ .*/group/find/all/\\$\\{traceId\\}/
