Hello, I need to dynamically change Grafana custom variable based on another query variable. This is needed to plug in values into a prometheus query and it will allow to see different graphs w.r.t custom variable change.
I have the following query variables that I use for a Grafana dashboards of my service:
- cluster_group -
label_values(kube_namespace_created{namespace="$namespace"}, cluster_group) - cluster -
label_values(kube_namespace_created{cluster_group="$cluster_group",namespace="$namespace"}, cluster)
When I open the service dashboard, cluster gets set as per cluster_group. For example, if cluster_group is set to A-1, then cluster will be set to A-1. I have A-1 and B-1 for the cluster groups and clusters of my service. And I mapped them to values of custom variables for dynamic query execution:
- downstream_cluster_group is equal to
A-1 : (X-1|Y-1|Z-1), B-1 : B-1 - downstream_cluster -
A-1 : (X-1|Y-1|Z-1|W-1), B-1 : B-1
Now I need to execute the query for a downstream service for a dashboard panel of my service in Grafana:
sum by (client_name, method) (
downstream_service:service_requests_total:rate1m{
prometheus="monitoring/downstream_service",
namespace="downstream_service",
cluster_group=~"${downstream_cluster_group}",
cluster=~"${downstream_cluster}",
client_name=~"my_service",
If cluster is set to A-1 I want Grafana to set downstream_cluster_group to (X-1|Y-1|Z-1) and
downstream_cluster to (X-1|Y-1|Z-1|W-1) and so on. But simply adding custom variables as described is not sufficient and there must be another approach or a workaround to achieve the goal
