Set a variable value based on the selection of another variable
Hi! I have the following request. I have a grafana variable let’s say “environment” which can have 2 values: STAGE and PROD.
I need to have another variable which I can use further in Prometheus dashboards, let’s call it “failures” and for that I need to have value 2 for PROD and value 3 for STAGE. Whenever I select STAGE from the variable drop down, the failures one should automatically have value 3 and the queries should run against that. Whenever I select PROD from variable drop down, it should automatically refresh value for failures to 2 and that value to be used in all the panels from that dashboard.
The only way I could find out was to actually separate the dashboard in 2. One for Stage and one for PROD and then I can control easily that failures value as I can define it as static.
Is there a way in grafana to have that dynamic set of variable based on the value of other value?
Should this work?
{{environment}_failures}
If variable composition works like this then I could have a variable called STAGE_failures and I could make use of it in queries if the replace works…
I got the same query !! any leads ?
