hi,
we are running grafana on AWS ECS service which has deployment configuration “Minimum healthy percent 100” & " Maximum percent 200" so that when we deployed any this on it 1st task will comes up then kill older task in such a way i want to achieve zero downtime for it. But when i tested it out it will goes down for 30 seconds (for 30 seconds i am not able to login to grafana). In docker logs i get this error -
logger=context t=2023-05-04T13:50:35.17526742Z level=warn msg=“failed to look up session from cookie” error=“user token not found”
logger=sqlstore.transactions t=2023-05-04T13:49:55.817085423Z level=info msg=“Database locked, sleeping then retrying” error=“database is locked” retry=0 code=“database is locked”
Can someone help me here? how can i achieve zerodowntime
THANK YOU!!
