HI Team,
We are trying to show values as table format based on JSON. We are getting all the values in same row but we are expecting row by row values. Could you please suggest how to solve that issue.
Json Data:
"result": "succeeded",
"name": "Initialize job",
"state": "completed"
"name": "Checkout gitleaks-config@main to s/gitleaks-config",
"name": "Checkout 14819-CD-ansible-testing@release/metrics-test to s/14819-CD-ansible-testing",
"name": "Finalize Job",
Table Showing same row:
Grafana version : v9.1.0
What happened?
It is showing same row all the values fron json data. -
It should be showed row by row
