How to read arrays from JSON where the keys are dates and value is the array using Infinity datasource plugin
    Grafana v10.4.0 (03f502a94d) Community Edition on Docker
    I want to show a table with the provided JSON below.
    With the Infinity data source, also tried with the JSON API
    I switched to Infinity to try out the UQL.
  • What happened?
    The rows in my tables are JSON strings instead of displaying them in the table.
    Display a table, preferably with the dates as columns and the objects within as rows.
The Json
    "2024-07-05": [
            "label": "student",
            "nb_visits": "32203"
            "label": "shopper",
            "nb_visits": "8145"
    "2024-07-06": [
            "label": "student",
            "nb_visits": "31703"
            "label": "shopper",
            "nb_visits": "6700"
    "2024-07-07": [
            "label": "student",
            "nb_visits": "32680"
            "label": "shopper",
            "nb_visits": "7916"
    "2024-07-08": [
            "label": "student",
            "nb_visits": "49184"
            "label": "shopper",
            "nb_visits": "11167"
    "2024-07-09": [
            "label": "student",
            "nb_visits": "47390"
            "label": "shopper",
            "nb_visits": "10809"
    "2024-07-10": [
            "label": "student",
            "nb_visits": "43619"
            "label": "shopper",
            "nb_visits": "8664"
    "2024-07-11": []
The closest I get to a table with UQL is:
parse-json
| project kv()
But it gives me a table like this:
Trying to add logic like this:
parse-json
| project kv()
| mv-expand date=key, visits=value
| mv-expand visit=visits
| project date, label=visit.label, nb_visits=visit.nb_visits
Just returns no data.
Using just the JSON type gives me a table like this:
Which is more like what I want, but I need the JSON arrays in the rows displayed correctly, something like:
label 2024-07-05 2024-07-06 2024-07-07 …and so on
student 32203 31703 32680 …
shopper 8145 6700 7916 …
How do I proceed?
Welcome @jorgeuos to the forum. I think you made a good start at this!
I am not very good at UQL, but I think that approach plus JSONata would work, but none of my attempts got what you desired.
Instead, I did a hybrid approach whereby I used some transformations to parse the JSON data:
You can summarize the data even further using transformations.
Nice! Thank you for your help.
I played around with the dataset now and I managed actually to do something that works for me. It even ended up being better than I expected according to my initial vision/goal.
parse-json
| project kv()
| extend "key", "Students"=tonumber("value[0].nb_visits"), "Shoppers"=tonumber("value[1].nb_visits"), "Total"=sum("Students","Shoppers")
| project-away "value"
I also added another query, with a transformation:
The other dataset:
  "2024-07-05": 40348,
  "2024-07-06": 38403,
  "2024-07-07": 40596,
  "2024-07-08": 60351,
  "2024-07-09": 58199,
  "2024-07-10": 66286,
  "2024-07-11": 5819
parse-json
| project kv()
| extend "Visits"="value"
And I could calculate the Delta in new column and give it a color:
