View json data in table - Grafana
Hello everyone,
I have json data in the following structure and I want to view id,severity,deviceDisplay etc in a table In grafana panel.
Im using Infinity Datasource , with the following uql query :
  "list": [
      "count": "304"
      "faultRealTime": [
          "faultRealTimeList": [
              "id": "9924511"
              "severity": "3"
              "deviceDisplay": "192.168.9.10"
              "faultDesc": "The instance \"[Interface:GigabitEthernet1/0/34]\" of \"performance task\" \"Interface Receiving Rate\" is in threshold range (\"\u003e=1Mbps\"), current value is \"1.398Mbps\"."
              "sourceIp": "192.168.9.10"
              "faultTime": "1662475220"
              "userAckType": "0"
              "userAckUserName": [
              "id": "9924510"
              "severity": "2"
              "deviceDisplay": "192.168.10.237"
              "faultDesc": "The interface GigabitEthernet1/0/20 is DOWN."
              "sourceIp": "192.168.10.237"
              "faultTime": "1662475121"
              "userAckType": "0"
If someone can point the error please or have any information that can help !
Use jsonata
parse-json
| jsonata "list.faultRealTime"
then Transformation of Extract Field
Thanks a lot, have a blessed day !
