I used the Infinity plugin to make a call to REST API.
The following is the JSON response with timestamp (epoch) and values.
"report": [
"timeWindow": {
"entityEpochSecUTC": 1625788800,
"entityTimeDurationSec": "SECOND",
"entityTimeField": "kafka_ingestion_time"
"entity": {
"entityType": "hive",
"entityNamespace": "db",
"entityName": "b_table",
"entityInstance": "server-ams4",
"dataAssetRef": "hive.db.b_table-v_1.0"
"reportItems": [
"checkName": "Check for cc info",
"checkLevel": "Error",
"checkStatus": "Success",
"constraintName": "containsCreditCardNumber",
"constraintStatus": "Success",
"constraintMessage": "string"
I am unable to get the values under reportItems. I tried to do reportItems.checkStatus , reportItems[].checkStatus and reportItems[1].checkStatus
Apparently reportItems[1].checkStatus do work in Grafana, however i need it to get all the records and and not just the first record.
Any help would be great.
Hi, I guess the answer is a bit late but I’ll give you an answer anyway, for the record. You can do do it in two ways with the infinity datasource:
- using
JSONPath:
- using
UQL language:
Hope this helps.
you can also use mv-expand to expand the array items in to row
parse-json
| scope "report"
| mv-expand "reportItem"="reportItems"
| project "ts"=unixtime_seconds_todatetime("timeWindow.entityEpochSecUTC"), "type"="entity.entityType", "check"="reportItem.checkName"
if we have a data which does not have “root” element,[{“date”:“2023-04-21T14:21:48.1092831+05:30”,“temperatureC”:47,“temperatureF”:116,“summary”:“Freezing”},{“date”:“2023-04-22T14:21:48.1092864+05:30”,“temperatureC”:20,“temperatureF”:67,“summary”:“Mild”},{“date”:“2023-04-23T14:21:48.1092867+05:30”,“temperatureC”:22,“temperatureF”:71,“summary”:“Hot”},{“date”:“2023-04-24T14:21:48.1092869+05:30”,“temperatureC”:30,“temperatureF”:85,“summary”:“Balmy”},{“date”:“2023-04-25T14:21:48.1092871+05:30”,“temperatureC”:14,“temperatureF”:57,“summary”:“Bracing”}] how can we parse such JSON using query languages (especially , if is the response obtained through an API)
Welcome @gmgangamanj
You can just simple use UQL
"date": "2023-04-21T14:21:48.1092831+05:30",
"temperatureC": 47,
"temperatureF": 116,
"summary": "Freezing"
"date": "2023-04-22T14:21:48.1092864+05:30",
"temperatureC": 20,
"temperatureF": 67,
"summary": "Mild"
"date": "2023-04-23T14:21:48.1092867+05:30",
"temperatureC": 22,
"temperatureF": 71,
"summary": "Hot"
"date": "2023-04-24T14:21:48.1092869+05:30",
"temperatureC": 30,
"temperatureF": 85,
"summary": "Balmy"
"date": "2023-04-25T14:21:48.1092871+05:30",
"temperatureC": 14,
"temperatureF": 57,
"summary": "Bracing"
Thanks for it. I too could do by directly providing the JSON and UQL as in Figure
. But when i provided an URL , no data is been shown as in Figure
. So if you could get me clarity on the data source plugin you have used and its configuration . It would be too helpful. Thank you once again
It is working now. It is working with localhost URL , once I have reestablished the localhost API connection. Thanks for the help
@yosiasz
