Variable Query originating: "Error updating options: Maximum call stack size exceeded"
Hi!
I have a dashboard with some panels that contain SQL queries that fetch results from a data source. One of this panels has a query which in turn use the results of a variable query in the ‘where’ condition.
Example:
select *
from my_datasource
where my_datasource.id in ($list_of_ids)
In the example above the $list_of_ids is my variable query which is fetching results on another different datasource. This panel works fine if the results from the variable query are few (dozens or hundreds) but I have some cases where the variable query get hundreds of thousands results and when that happens I get the following error message: "Error updating options: Maximum call stack size exceeded"
Is there a way to solve this issue?
Thanks in advance!
The same thing happens to me, is there a solution for this error?
What happens if you take the query (check the Query Inspector) and run it outside of grafana in a query tool for MySQL?
