grafana enterprise-10.3.1 -
What happened?
Hi all,
The error I have is that, when upgrading from version 10.2.2 to version 10.3.1, the most recent version, I get the following problem with the variables:
But when I change the variables configuration and disable the multi-value option, the error stops appearing. In version 10.2.2-1 I did not have this problem.
I leave you the query of the variable in question:
What could be happening? As I said, in the previous version I didn’t have this error.
Best regards
