Dashboard Variable Loki query option issues
    v11.2
    Filter the label “filename” which under job and instance
    Create Variables with query options
  • What happened?
    I recently upgrade my Grafana from v10.4 to v11.2
    the dashboard cannot filter the label value base on my define and show all values
Here is the current query options which working in v10.4
If I am using label browser, it can be sort out the correct one.
    No
    NO
