→ Grafana 8.0.1 on Windows Server -
→ Update system from 7.5.4 to 8.0.1 -
→ Update based on Upgrade Grafana | Grafana documentation -
What happened?
→ MSSQL based Dashboard shows error
→ Dashboard variables can’t be initialized
("Error updating options: Query error: 400 Bad Request)
→ variable query looks like "select distinct project from work_items_pr ] -
→ no error like in version 7.5.4 -
→ yes: “Error updating options: Query error: 400 Bad Request”
hi @pecs,
Glad you got this working. There are several patches that were released in 8.0.1 and 8.0.2 that dealt with SQL issues. If this returns, I’d try upgrading and testing again.
Hi!
I have the same issue with a Postgres datasource.
The variables are failed with “Error updating options: Query error: 400 Bad Request”
In the datasource settings, the interval is set to default.
When I click “Save & Test” the datasource is happy.
Does anyone know what the issue could be?
I have the same issue with MySQL data source.
I’m using the below dashboard for MySQL DB
Thanks
I have the same problem with Grafana 8.1.3 and Postgres datasource.
Templating [variable]
if I am using a data source configuration file(yaml) to configure the default source what attribute represents Minimum time interval in the data source. Would it be “time interval” as defined here, Provisioning | Grafana Labs under the JsonData section
By the way I am using a docker container to run Grafana and volume mounts the configuration
apiVersion: 1
datasources:
- name: PostgreSQL
type: postgres
url: 192.168.71.140:5432
database: mydb
user: mydb
secureJsonData:
password: "xxxxxxxx"
jsonData:
sslmode: "disable"
postgresVersion: 1200
timescaledb: true
