I found an error grafana bad request 400 my host
found message on grafana this error bad request
error sometime refresh grafana
Hi @prasinp,
Welcome to the
community support forums !!
Please review the submission template and include more details:
Grafana v9.2.2 oos edition. I run dockercompass os linux ubuntu
What is your datasource?
datasource = grafana
bad request 400 sometime to grafana datasource
Do you mean Docker compose?
If yes then, did you already check the documentation regarding it i.e.
I check done I run Grafana 8.5.6. no problem
I update 9.2.2 I see error bad request
Can you please provide the steps of reproduction so that the community can also try to reproduce it on a test machine?
Also, share your docker-compose file so that I test it as well
Thanks.
change code grafana on docker-compose.yml and ssh machine grafana and git pull grafana 9.2.2 version and I run grafana composs
Hi @prasinp,
Also, share your docker-compose file so that we can check it.
Lastly, 2 more additional questions from your recent comment i.e. :
1- As you said that the 400 error appears not always but only from time to time. Can you please check the logs whenever it happens as the logs are located at /var/log/grafana/grafana.log
2- You said initially that you are using docker-compose but later in the recent comment saying about pulling grafana via git. I do not completely understand it so kindly explain in a bit more detail as initially asked i.e. provided step-by-step details of reproduction.
I found error
*476119 upstream prematurely closed connection while reading response header from upstream
Thanks.
So to my best knowledge, this does not look like a Grafana issue but either:
1- Docker side (network)
2- Web server side (Apache/Nginx timeout)
For the latter one, it can be fixed by increasing the timeout value in the configuration file.
But if there is no Web server or even a reverse proxy involved then, probably ask Docker Community about it.
I hope this helps.
Hi @prasinp
Did you find a solution or is this is still on-going?
We would like to know the updated status ![]()
Thanks
