Hi! I’m having a bit of a trouble to get Grafana working. I have set up InfluxDB correctly, this is, I’m getting data in there. But I seem to have gotten stuck on connecting to Influx from Grafana. As you can see I’m getting a “Bad Request” error. Whenever I try to write in faulty connection details I’m getting the error “Bad Gateway”. So the connection details seem to be correct but there is something else that is not working.
Anybody have any suggestions?
The IP adress of my Home Assistant is 10.52.65.102:8123. Although I write homeassistant.local.8123 in my browser to access it. I have tried localhost and some different ports like 8086 but that doesnt work. Strangely, In the influxdb integration i configurations.yaml I had to use port 8086 for it to work. But using that port in Grafana does nothing.
