Hello to everyone!!
I’m trying to create a dashboard to read data adquired on a InfluxDB database on a Raspberry pi 3. In order to achieve my goal I want to use grafana cloud dashboards, this way I can access with any computer to the data stored on the raspberry.
The problem is the following: “Network Error: Bad Gateway(502)”. This error appears when I configure the Database on the grafana cloud session.
I tried to work locally and both the database and grafana, which are installed in the raspberry, and the dashboard works. I can visualize the data. The configuration is for the localhost.
Any suggestions?
Thank you in advance.
Best regards, Iñigo.
