Query Variable: Unable to parse SQL LENGTH function
    • v8.0.0 (41f0542c1e)
    • Assign value to dashboard variable by getting LENGTH of value of another variable
    • As a query variable. Following query:
    SELECT LENGTH(${location_ids:sqlstring});
    // even trying the following gives None as value
    SELECT LENGTH('grafana');
  • What happened?
    • This query was working just fine until I upgraded to Grafana 8.0
    • Work as expected
    • No
    • No. All of my errors originate from not being able to parse LENGTH of an already existing dashboard variable
    • Not applicable as Dashboard was working just fine previously under Grafana 7.X
Hi @pupdogg
Have you tried toggling table view in the query editor? The SQL datasources changes how they render data frames in g8, so some queries will need to be adjusted.
here is a note about those changes:
